Sifu
- Joined
- Sep 3, 2011
- Messages
- 3,318
The code requires cross ventilation of attic spaces and specifically indicates that where the ceiling is applied directly to the rafters (sloped ceilings) the rafter spaces must be ventilated. In the last few days I have run across a number of installations that did not provide baffles. Of course arguing ensued when I wrote corrections. I decided to check my premise. The code for insulation clearance says "where eave or cornice vents are installed" and indicates a 1" air space. It does not require eave or cornice vents.
So in one case, a shed roof, cathedral ceiling on the inside, I asked for what I used to install back in my builder days: either a side-wall vent at the top or roof vents with cross ventilation within each 2x12 rafter along with eave ventilation and baffles thus providing the entire roof with cross ventilation.
In another case, an addition with the rafter tie/CJ installed higher up on the rafter forming a sloped portion of ceiling. The eaves stuffed tight with fiberglass and the rafters blown in with cellulose and no baffles. I required baffles.
The code asks for ventilation, indicates a reduction when a percentage is installed in both the upper and lower portions of the attic and indicates eave vents may not be required. So to my question: Is there code language indicating where ventilation must come from? In the first case could it all come from the eave with none at the top? And in the second case could the eave ventilation be left out, thus negating the need for the 1" air space?
IMO cross ventilation indicates that ventilation must "cross" the roof, which would mean top and bottom given that heat rises. Since nobody here actually has a code book I usually have to defend my corrections (to my BO) with code language or good interpretations and I am having trouble finding solid ground in that respect.
Any thoughts are appreciated.
