You can add the electric latch retraction (EL/QEL) retrofit kit to your existing fire exit hardware, which will release the latch to allow the door to open automatically. You will also need a door loop or other type of power transfer to get the wires to the door. Because the doors are fire rated, you will need to have a fire alarm contact to cut power to both the operators and the ELs.There may be a solution available from another manufacturer as mentioned in the responses above - just check to make sure they're acceptable for use on a rated door. Also, check to make sure the preparation for the product does not exceed the allowable field modifications on a fire door / frame - typically a 1-inch diameter hole is the limit without having the opening relabeled (this can get expensive). If your panic hardware has bottom rods and latches, you would need to remove them and add the less-bottom-rod (LBR) retrofit kit so the electric strike/controller is releasing just the top latches. You should check with the door manufacturer, especially if the doors have been in place for a while, to make sure it's acceptable to use the LBR devices on them.
If you need help getting the Von Duprin retrofit kits or choosing the specific hardware that you need, I can connect you with the local rep. If you want to email me directly, my email address is
lori.greene@allegion.com.
