Can a newly built house passes inspection if it doesn’t have stairs or deck at backyard door which is 2ft above grade? I see builder sells the house without that even it seems code requires one:
“R311.3.2 Floor Elevations for Other Exterior Doors
Doors other than the required egress door shall be provided with landings or floors not more than 73/4 inches (196 mm) below the top of the threshold.”
If it does pass, can owner build a stair or deck (less than 200 sqft) without permission (it seems there are requirements that the structure need to be some ft away from the house to get exception)
If it does require permission then does it require to meet footing under frost line requirement?
