I'm thinking it just looks like an encasement for some conduit rather than a footing.No rebar or anchor bolts sticking up and the footing is buried.....makes me wonder what the footing is for. The forest of pvc is another question.
What is all of the white pipe for?
That's an awful small footing compared to what we normally see around here for tilt up construction. Unless I'm totally missing it it's < 2'0" wide and < 1'0" thick. This obviously has to be in California or some warm place because of footing has absolutely no depth. You know what the supporting capacity for this soil in that area is?In this case it is tilt-up precast wall construction. The conduits are feeders to the different distribution panels. After the slab is prepared there will be a lot more conduits for the branch circuits. It was expected that the EC would have to do this and a plan was already in place for flowable fill and a special inspection through engineering.
Regarding the white pvc piping, ...in the lower left
corner of the pic., there is some gray duct tape on
the piping.......Is this to cover a possible leak \
hairline crack in the pipe, or other ?..............Has
a water test been performed yet ?
Yes, El Jeffe I know that you do not do the plumbing
inspections any longer, but us inquiring minds wanna
know !
If there are no point loads spread the sleeves out so they are 4" apart and pour flowable fill.
