LandracePharms
So I lease an office/warehouse space and in the warehouse space that is 27.5' x 60 ' with a single slope roof 14'-18'. It is a steel-framed building with a brick facade and sidewalls. My space is the first one so I have 3 exterior walls. The building has parapet walls along the front and sidewall so the roofline is level. on the inside all of the walls are sheetrock except the long exterior wall(sidewall). I can see where they had furring strips screwed to the girts all down the 60' like it was going to be sheetrocked as well but the wall was left with the steel girts and the insulation with the reinforced white backing exposed. Well because the wall was not finished the parapet wall cavity was left open to the interior space. When I look up I can see up inside the parapet, which also has a ton of air leakage. If you stick your head up there when the wind blows your hair moves. There is no insulation on the parapet's inner wall, just sheet metal. So in the winter when the heater is used the warm air rises up into the parapet causing condensation which drips down constantly and creates mold and health problems. The condensation will also run down to the back wall and go behind the sheetrock.....on the other side of the building on the other end suite that has the same wall it is sheetrocked and they have no condensation problems. Shouldn't the builder have closed off the parapet by sheetrocking the wall and sealing it off so it would not have a problem? That much air leaking would make sense if it was going to be closed off... The way it is it is costing even more to heat the place because all the heat goes out the parapet. Would, or should have, the open parapet pass inspection? the air leaks... no building envelope.... Fire inspection? Who would be liable if the problem caused my business a major loss due to mold? the builder? the landlord? No one, just suck it up and fix the builder's failure myself? Shouldn't the landlord go to the builder about a warranty??
Am I just supposed to take the loss (over $10,000) and have the issue fixed?
oh yeah...... I leased the space before the rest of the units were finished so I talked to the superintendent and builder a few times...I noticed the problem and asked the builder about it and he played dumb, said he would come to look at it but never did.... My walls were not painted either... they still need to be sanded and finished before they would be ready for paint. I think they were behind and took down the furring strips and just left it unfinished because the realtor leased it to me too early... does that change who might be liable for my damages/loss? Should the building even have passed inspections?
