bank vault fire sprinkler
cheyer
Sunny California..well mostly..
Interesting question was posed to me today asking whether or not a fire sprinkler was required inside the bank vault...my gut feeling was that, well its already well compartmentalized and the door is closed way more than it is open......so what are some of your thoughts?
Thanks
Agree and all of ours where applicable are sprinkled. There are measures that can be taken if the facility has concerns regarding "records" being damaged by water if stored in the vault.
I respectively disagree. This is one case where NFPA makes an expection. NFPA 232 for critical records storage Section 6.13.1 requires either sprinklers per NFPA 13, water mist per NFPA 750 or clean agent per NFPA 2001. To qualifiy for this provision, the vault would need to be constructed as specified in NFPA 232, which includes significant construction and greatly limiting the openings into the vault. Clean agent should be permitted in this condition.
In the good old days that was one of the exceptions
do not have IFC, did they take that out???
903.3 Installation requirements. Automatic sprinkler systems
shall be designed and installed in accordance with Sections
903.3.1 through 903.3.7.
903.3.1 Standards. Sprinkler systems shall be designed
and installed in accordance with Sections 903.3.1.1,
903.3.1.2 or 903.3.1.3.
903.3.1.1NFPA13 sprinkler systems. Where the provisions
of this code require that a building or portion
thereof be equipped throughout with an automatic sprinkler
system in accordance with this section, sprinklers
shall be installed throughout in accordance with NFPA
13 except as provided in Section 903.3.1.1.1.
903.3.1.1.1 Exempt locations. Automatic sprinklers
shall not be required in the following rooms or areas
where such rooms or areas are protected with an approved
automatic fire detection system in accordance
with Section 907.2 that will respond to visible or invisible
particles of combustion. Sprinklers shall not
be omitted from any room merely because it is damp,
of fire-resistance rated construction or contains electrical
equipment.
1. Any room where the application of water, or
flame andwater, constitutes a serious life or fire
hazard.
2. Any room or space where sprinklers are considered
undesirable because of the nature of the
contents, when approved by the fire code official.
3. Generator and transformer rooms separated
from the remainder of the building by walls and
floor/ceiling or roof/ceiling assemblies having
a fire-resistance rating of not less than 2 hours.
4. In rooms or areas that are of noncombustible
construction with wholly noncombustible contents.
903.3.1.2 NFPA
