Bare neutral in subpanel
BJN
Kansas
https://www.dropbox.com/s/g9jkimw6yxgplah/IMG_1668.JPG?dl=0
So, in this subpanel, the big aluminum neutral wire entering the panel is not insulated. This is an existing home, but the service was upgraded to a 200 amp service and the subpanel is brand new.
I’m not an electrical inspector (yet), this is a panel I saw on YouTube.
2018 IRC E3406.5 “... Except where otherwise permitted in Sections E3605.1...current carrying conductors shall be insulated.
2018 IRC E3605.1, #2 says that “An aluminum or copper-clad aluminum grounded conductor shall not be required to be insulated where part of a cable...”
Is that neutral part of a cable? Or is it an individual current carrying conductor
IF this is a sub panel and not a service disconnect, then, the SE cable they ran as a feeder is incorrect and they should have run a 4 wire with an insulated neutral. The fact that the bonding screw is in place is also incorrect IF this is a sub-fed panel AFTER the service disconnect. If this is a service panel/disconnect then there is nothing wrong with what is visible from a viewpoint of a photo without actually seeing the entire panel.
Thank you, very helpful information.
It might be a main panel... it was the home owner narrating and moving the camera, so who knows...
