dartmouthrocks
I would appreciate help on a square footage issue for a Colorado home. Does anyone have experience whether counties/assessors typically included the square footage of a below grade level of a home (would have been called a “cellar” in New England) within the calculation of a home’s square footage in the 1983 time-frame?
The assessor has not included the cellar in square footage calculations since the home was built.
No as-built plans exist in the Land Use file (home has stepped foundation — built into a hill) and the majority of the cellar had ceiling heights now acceptable by the county as potentially habitable space. (The cellar floor is decomposed granite.) Initial building plans showed a crawlspace — on the other hand, the same set of plans included a “basement option.”
Thanks for any help on whether cellars typically had their square footage counted within the ambit of a home’s square footage (in the early 1980’s time frame). This may seem may like a strange question to ask, but it is affecting whether the county will permit cement and an interior french drainage system to ward against moisture/mold issues.
Thanks for any insight. Links to codes and reputable sources are greatly appreciated.
