Basement Doors
Mech
Eastern PA
2009 IBC
Are Bilco style basement doors code compliant if accessibility is not required?
Section 1008.1.2 Door swing. Egress doors shall be of the pivoted or side-hinged swinging type.
1.Private garages, office areas, factory and storage areas with an occupant load of 10 or less.
2. . . .
Section 1008.1.3 Door opening force. The force for pushing or pulling open interior swinging egress doors, other than fire doors, shall not exceed 5 pounds (22 N). For other swinging doors, as well as sliding and folding doors, the door latch shall release when subjected to a 15-pound (67 N) force. The door shall be set in motion when subjected to a 30-pound (133 N) force. The door shall swing to a full-open position when subjected to a 15-pound (67 N) force.
For window exit or in place of a normal door??
If door seems like special knowledge
cda said:
For window exit or in place of a normal door??If door seems like special knowledge
Should have asked also commercial or residential
If commercial what is the door serving and sq ft?
This is on a commercial building. The basement / extremely tall crawl space will either be storage or utility.
why not, more tha likely the hatch will remain open when someone is in there
