Basement/Garage door
Wrecks24
Tennessee
So I live in a home where the garage/basement is under the house. There is a stairway up to The living room. The stairway “zigzags” back up to the living room with a small platform in the middle. The door at the top of the stairs is basically a standard interior door. My question is, should it be a fire rated door? Seems like the floor of my living room would catch fire before it ever reached this door.
No
Unless the local city requires it.
About how old is the house?
Normally the door from the garage into the house is either a certain thickness or rated, depending on the year it was built.
Do you own the house????
Yes I own the house and it was inspected before buying. I just wanna know its right. House was built in 2006. The stairway is sheet rocked, if that matters. The door doesn't open directly to the garage as you go down one set of stairs to a landing, turn and go down another set into the garage/basement
Ok will say it this way
The door from the garage into the basement or any part of the house
Should be the one that is either thicker or rated.
If your house is in an incorporated city, it should meet code.
Being the owner you can change that door for added safety.
Thank you. I live in the county and its not so much me being worried about it as it is for resale later down the road. All the houses in my little subdivision have basically the same set up. We are looking a few years down the road selling and buying a farmhouse.
The garage is directly under my living room with open floor joists and seems like that would burn before a fire would even reach the door.
So you are standing in the garage
Look up and see wood studs/ rafters/ supports??
And the living room or other living is directly above this??
Apparently thats how we roll in the County, every house in the neighborhood is the exact same way. So I guess my worry about the door is The least of my worries...lol
There may be a reason it is that way.
Will let others comment
Rated dry wall does not cost much and if you can use a screw gun and have a helper, it can be done. Youtube
Or if you have a construction friend, fix him a steak dinner.
I am getting ready to redo my garage ceiling
It has a few foot holes in it.
I am not familiar with the codes that are/were in effect in other locations. I can tell you the possibilities that I am familiar with.
1. The ceiling is protected with 5/8" Type-X drywall or equivalent and so are the elements that support the ceiling such as walls and beams.
2. The Ceiling is protected with 5/8" Type-X drywall or equivalent but the elements that support the ceiling are protected by 1/2" drywall or equivalent.
Doors have always been similar to this.....
solid wood doors not less than 1-3/8 inches in thickness, solid or honeycomb-core steel doors not less than 1-3/8 inches thick, or 20-minute fire-rated doors, equipped with self-closing or automatic-closing and self-latching device.
I copied this right out of the CRC "solid or honeycomb-core steel doors not less than 1-3/8 inches thick." I have never encountered an 1-3/8" solid steel door. I must be missing something in the translation.
In my code there's a blurb about the door being "tight fitting" but I can guarantee that my code was never enforced in Tennessee.
There is a third possibility which is what you have currently. If there were no codes adopted or no oversight, then anything is possible.....and perhaps legal. If it were me I would retrofit to possibility #1.
You "should be" concerned. Fire separation of a garage from occupied space, whether adjacent to or above it has always been a tenant of codes. Ask your insurance carrier if it is acceptable to them.
The first thing i would do before I went to sleep in that house another night is install a really good smoke detector throughout and the next morning I would install 5/8 sheetrock all over that garage as well as a decorative fire rated entrance door whether its required in your municipality or not.
Large areas of TN do not have inspection departments, the more rural the more likely. Sounds like you may have been in one such area. Current code would require 5/8" type X on the ceiling, 1/2" for supporting structure and common walls. Not sure what code would have been enforced (if there was enforcement) at the time but I checked the '03 code and it was the same. I have seen many like it there. Could it be a problem for resale? Maybe. If I were the inspector it wouldn't go unnoticed. Could it be a problem for you and your family? I wouldn't wait to find out. I have seen many garage fires that stopped at that separation. It is a simple but very effective life-safety measure.
