Sifu
- Joined
- Sep 3, 2011
- Messages
- 3,315
I have a group H building that requires 2-hr rated exterior walls per t602. The exterior wall is a concrete stem wall where below grade with PEMB on top, so the exterior wall is partially below grade (8') with earth behind it. On one of the walls that require the rating there is a 3' wide x 4'10" tall tunnel used for process piping and equipment run between the new building and an existing building. By definition, the exterior wall is both the concrete below grade portion and the PEMB above grade portion of the wall. The above grade is appropriately rated, but per plan the below grade portion is not (aside from the inherent qualities of the construction). I wouldn't think to require a rating for the below grade portion except now there is a tunnel opening providing a direct path to the adjacent building so my thinking is that any process piping or other elements passing down this tunnel would be required to pass through appropriately rated through penetrations. Anyone seen anything like this or have contrary thoughts?
