mark handler
SATURDAY, AUGUST 20 CALIFORNIA RESIDENTIAL CODE USING CODE CHECK BUILDING 3RD ED.
SATURDAY, SEPTEMBER 17 THE 2008 NATIONAL ELECTRICAL CODE USING CODE CHECK ELECTRICAL 3RD ED.
SATURDAY, OCTOBER 22 CALIFORNIA PLUMBING & MECHANICAL CODE
8:00 A.M. – 4:30 P.M. FOR EACH SEMINAR
Continuing education credits: earn seven (7) ashi ces. Also qualifies for icc ceu’s
Truitt & White Conference Room
1817 Second Street, Berkeley, California
SATURDAY, AUGUST 20, 2011 CALIFORNIA RESIDENTIAL CODE
Using Code Check Building 3rd edition (included with registration)
This class is essential for contractors, inspectors, architects, home inspectors, fire prevention officers, plans examiners, and anyone planning a building project. The class includes a copy of Code Check Building 3rd edition, the latest release in the Code Check series. Like the new California Residential Code, the book is based upon the 2009 edition of the IRC. This class explains the limitations of the new residential code and why some projects require both the residential code and building code. Other topics include fire-resistant construction, fire protection, habitability, glazing, decks, stairs, guardrails, foundations, drainage, floor framing, wall framing, seismic bracing, roof construction and coverings, interior and exterior wall coverings, and much more. The seminar includes issues that coordinate with California’s energy code and green building code. Practical examples are used for
all topics to show how the new codes apply to real-world situations.
SATURDAY, SEPTEMBER 17, 2011 THE 2008 NATIONAL ELECTRICAL CODE
Using Code Check Electrical 6th edition (included with registration)
The 2008 National Electrical Code is now in effect in California, with expanded requirements for AFCIs, GFCIs, tamper-resistant receptacles, and numerous changes in wiring methods and equipment. This class includes those changes and rules for services, grounding, bonding, load calculations, panels, multiwire circuits, boxes, branch circuits, receptacles, bathrooms, kitchens, switches, lighting, appliances, ampacity, cable systems, raceways, photovoltaics, swimming pools and spas, generators, and special problems posed by older wiring. This class is appropriate for building inspectors, electricians, home inspectors, general contractors, remodelers, and designers. As with all Code Check presentations, it uses real-world examples and the instructive illustrations of Paddy Morrissey, the designer of Code Check.
For more information or to register, visit http://www.ggashi.com/chapter_events.php
SATURDAY, OCTOBER 22, 2011 CALIFORNIA PLUMBING & MECHANICAL CODE
Using Code Check Plumbing & Mechanical 4th edition (included with registration)
Plumbing and mechanical equipment installations are becoming increasingly complex as new materials and methods are used, including PEX tubing, tankless water heaters, mini-split systems, and more. This seminar covers the basic code requirements and principles for these systems, including pipe materials, drainage, backwater valves, traps & vents, water distribution, gas piping & tubing, water heaters, fixtures, water conservation, furnaces, air conditioners, ventilation, ducts, boilers & hydronics, direct-vent appliances & fireplaces, combustion air, venting, clothes dryers, exhaust systems, and indoor air quality. This seminar is an opportunity to obtain the latest Code Check Plumbing & Mechanical book (slated for release to the general public on November 1) and to stay up to date on plumbing and mechanical codes.
http://www.google.com/url?sa=X&q=http://www.codecheck.com/cc/ccimages/PDFs/CC_Seminar_Series.pdf&ct=ga&cad=CAcQAhgAIAEoATAAOABA0f_78QRIAVgAYgVlbi1VUw&cd=ZEgL7OOAkfY&usg=AFQjCNEFtDoh2qE_2I8o0ysz5vDm6tBs3Q
FEES & REGISTRATION
Space is limited. Early registration is strongly recommended.
Members of Golden Gate ashi: [Earn seven (7) ashi ce’s for each seminar]
Save $37! $400 For all three seminars (with registration by 8/15/11)
8/20/11: California Residential Code: $129 (add $10 if registering after 8/15/11)
9/17/11: National Electrical Code: $159 (add $10 if registering after 9/12/11)
10/22/11: California Plumbing & Mechanical Codes: $149 (add $10 if registering after 10/17/11)
General Public:
S ave $32! $450 For all three seminars (with registration by 8/15/11)
8/20/11: California Residential Code: $144
9/17/11 National Electrical Code: $174
10/22/11: California Plumbing & Mechanical Code: $164
Reserve on-line using a credit card by visiting www.ggashi.com/chapter_events.php
or mail a check made out to GGASHI to GGASHI CodeCheck– 563 Brookfield Drive – Livermore CA 94551
Remember to provide your name, contact information, and payment, indicating your choice of seminar(s)
Questions? Email info@ggashi.com or call 707-313-4934 to leave a message or send a fax.
CANCELLATION POLICY: If you do not provide at least 72 hours notice for cancellation, your fee is transferrable to another individual
but is NOT refundable. Payment required in advance to reserve your spot
FEES & REGISTRATION
General Public:
