BlazeMaster Approval for Exposed Locations
Yes, but if you look at the manufacturer's specifications, you'll find this:
"Use of BlazeMaster CPVC pipe and fittings is limited to basements where the quantity and combustibility of contents is low and fires with relatively low rates of heat release are expected."
I'm not sure what the general consensus on this one will be, but I'm not inclined to believe that an unfinished basement will have low quantity and combustibility of contents with fires of relatively low rates of heat release - most unfinished basements are one big storage area filled with a wide array of combustible materials, with no compartmentalization.
The article only mentions using the CPVC with composite wood joists. Is this an expansion of the listing or is this only allowed with the composites? What about dimension lumber joists or floor trusses?
Joe
