123pugsy
Bronze Member
I'm planning a renovation where by I will knock down my bungalow and add a two story addition.
It's got a 10" block foundation wall. I have siding three sides and brick veneer front. I plan on taking down all 4 walls and start from scratch keeping the foundation and first floor floor joists. The sill is not currently bolted down (built in 66-67). This is a good thing as I plan to cut back the first floor joists to create a brick ledge. The bad thing about it not being bolted down is that the top course of block are hollow and also have closed tops.
Can I core a hole into the cells to fill with grout? I would also need to use Titens or Quickbolt 3's to bolt the new sill plate down as I need to slide it under the existing floor joists. I can not lift it over cast in anchors.
When grouting cells for anchors, does each cell in a block (these have 3) need to be filled?
Thanks for any answers to these questions and any other comments as well.
Pugsy
Pugsy
