Bosch solar panels Recall
mark handler
So. CA
Bosch Solar Services Recalls Solar Panels Due To Fire Hazard
https://www.cpsc.gov/Recalls/2017/Bosch-Solar-Services-Recalls-Solar-Panels
Roof-mounted Bosch solar panels
Hazard: The solar panels can overheat, posing a risk of fire.
This recall involves Roof-Mounted Bosch Photovoltaic Solar Modules with model number c-Si M 60 NA30119. Bosch solar modules are photovoltaic solar panels used to generate electricity. Each module measures approximately 65 inches by 39 inches by 1.65 inches, and weighs just less than 42 pounds. The solar cells are housed in a glass-foil laminate framed by an anodized aluminum profile. The output power of the panel is 245 watt peak.
