mgnswn
Hi!
I am a small business owner with a construction team doing tenant improvements on my new space.
They built steel door frames for a wood door jamb. My uncle performed a walk thru of their work and noted that the door frames should be reinforced with a 2x4 to support the door installation. He said this is considered a best practice. Any thoughts on this? I asked my construction team about this and they contested that internal steel door frame support is not needed; however, I assuming they wouldn't say otherwise since it would mean a hefty redo of the work.
Is some sort of door support/reinforcement needed? Is there a formal standard/code that I can show my construction team and force them to fix? I did not pull a permit for the work so it is just me doing the inspection
Any help and advise would be greatly appreciated. Construction is not my line of expertise.
Thank you!!!!!!
Megan
Thank you!!!!!!
Megan
