ELLEN09US
per Figure 11B-403.5.1 clear width of an accessible route is 36". Is this correct? or 44"?
36" is the minimum for the accessible route.
The figure you are referring too shows how narrow and for how long of a distance the width may be reduced below 36".
exception 2: occupant load more than 10 has to be 44"
Thank you all!
"...minimum width shall be not less than that specified in Table 1020.2. ..." it can be required wider based on other sections in the codeELLEN09US, doesn't table 1020.2 imply that "50 or more" would be 44", not "10 or more"?
