Can the City require a vehicular guard rail between properties?
Lincoln
A concerned citizen has reported that there is no vehicular barrier that would prevent someone from driving over the edge. The 2009 IBC does not require a guard rail for areas that are more than 5 feet away from walking surfaces. To my knowledge, there is nothing in the current Design Standards that would require a vehicular guard or visual barrier.Although I agree that the situation looks precarious, I am thinking that there is nothing that would require these property owners to do anything about the potential danger.Thoughts?
/monthly_2011_09/NoGuardRail3.jpg.7cfe7b8411990a9b0a23b27d29878284.jpg
Thoughts?
Did your jurisdiction adopt appendix J? No barricade requirement but slope constraints. Who created the drop? Is it a cut or fill?
That's just what we need a standard for incompetent motor vehicle operators.
A municipality if regulated would have such in site / land development standards but not likely to be a building code issue as per diagram.
No Walking surface, and if we are not able to construct potentially dangerous to the feeble of mind how would Jack*ss and Americas Funny videos make a living?
Thoughts?
I don't find this language in the 2009 - could you reference a code section for the 5 feet away part...?
Thoughts?
I have seen provisions for something like this either in zoning regulations or in developmental and mixed-use agreements where the risk was assessed at the planning/civil engineering phase. Zoning would be your best bet at this point.
Architect1281 said:
That's just what we need a standard for incompetent motor vehicle operators. A municipality if regulated would have such in site / land development standards but not likely to be a building code issue as per diagram.
Accommodations for the intellectually disabled?
More of a Planning & Zoning issue. It should have been addressed when the original site plan maps were presented to the Planning Commission.
A concerned citizen
Maybe they need to re-take their drivers test. It looks like a drive up window lane, how fast will a driver be going? There is a curb and the concerned citizen wants a guardrail to run into.
It might depend on the franchise. We have Jimmy John's (delivers sub-sandwiches) franchises here, and they are 'so fast you'll freak' (slogan)...but not sure if that translates to the drive-thru lane as well.
Design Standards...Thoughts?
Public Works/Civil Engineering Department might have an adopted design standard you may be able to reference. Still I believe it would be a very difficult road to travel to require a guard rail at this juncture. Perhaps if there were actual cases of vehicular endangerment, you could make a case for public safety...still a stretch.
What about the interstate system, it does'nt have a guardrail through out?
I could go off the road and my wife would never miss me and start dating that golf pro again.
pc1
