Cast in Place Concrete for Apartment Complexes
Are any of you seeing a rise in this type of construction? For those not familiar, it is a cast in place process that is like stacking boxes except they are poured in place (cast in place)
Not in my neck of the woods, but looks like it may be used in hurricane-prone areas. In my area, there is a lot of post-tensioned slab construction with concrete columns and light-gauge metal stud framing, but not concrete and masonry walls.
A lot of our coastal condos are post tension.
There’s a $100 million fix proposed by the owners association that is stuck in plan check.
While this may not be the typical system for residential buildings of this type in an area, there do not appear to be any reasons why it is not appropriate. Too often we assume that the type of construction that we are used to seeing locally is the only way things are done.
Just because it is concrete residential construction there is no reason to associate this project with the Millennium Towers project. There have been no creditable claims that there was any problem with the superstructure.
Given the blowback from the foundation problems with the Millennium Towers the San Francisco Building department is running scared and may be subject to regulatory overreach. If you read IBC Chapter 18 you will find that while there a numerous reporting requirements there are y no code provisions that would address prediction of foundation settlement.
And yet most soils reports address estimated settlement, didn't theirs? Especially knowing the depth of the underlying material.
I believe the foundation decision was a "value engineering" decision.
Estimating settlement is not like calculating beam deflections. A lot of assumptions need to be made and even the best soil sampling program leaves a lot unknown. To blame something on value engineering, of which I am not a fan, ignores the reality that a lot of decisions are made based on the perceived costs.
We do not know the cause of the problem and without more data can only speculate.
Before construction of the Millennium Tower began respected engineers advised against building with concrete due to the enormous weight. Sometime into the construction the building started to lean. That’s because of the weight. The reaction to that was to add more weight. Engineers are responsible from start to finish.
