Ed Cooke
Hey Folks,
I have had a small rash of questions pertaining to above ground pipe failure lately. I wanted to post what generally happens to Cast Iron after a time, and no, I am not a scientist to give the timeframes although I see this normally after decades of great service where installed correctly:
.....Since cast iron is made of metal, hydrogen sulfide gas can create a chemical reaction between the waste and cast iron when the pipes have waste flowing through them. When the gas oxidizes, sulfuric acid is created and causes corrosion within the pipes. This results in the common rusting pipes from the inside out. It also occurs in venting systems that are in conditioned spaces subject to heat and cold to varying degrees throughout their service life.
Hope this clarifies what may happen, so there is the why. But if you do repairs, thank whoever designed and/or installed this. Now go create the service call and get to it! Great position to be in, ehh???
