Yikes
I have a client with a 140 unit California apartment building built circa 1968. The existing bedroom escape windows presumably complied with code at time occupancy, but do not comply with current code for max sill height. Replacement windows were installed under permit in the early 1990s, and they are due for another replacement. However, the current code official is telling them the replacement must comply with current code for emergency escape, including max. 44" AFF sill height. this means that a simple wiodw replacement job becomes a major demo and reframing and re-stucco job.
My read on CBC 34 is that in-kind replacements should be allowed without having to reframe the openings, provided they don't create an additional hazard. Am I correct?
Code references:
3401.4.2 New and replacement materials. Except as otherwise
required or permitted by this code, materials permitted
by the applicable code for new construction shall be
used. Like materials shall be permitted for repairs and alterations,
provided no hazard to life, health or property is created.
Hazardous materials shall not be used where the code
for new construction would not permit their use in buildings
of similar occupancy, purpose and location.
3404.1.1 [Alterations] Replacement, retention and extension of original
materials. [bCD1] Local ordinances or regulations shall
permit the replacement, retention and extension of original
materials, and the use of original methods of construction,
for any building or accessory structure, provided such
building or structure complied with the building code provisions
in effect at the time of original construction and the
building or accessory structure does not become or continue
to be a substandard building. For additional information,
see Health and Safety Code Sections 17912, 17920.3,
17922(d), 17922.3, 17958.8 and 17958.9.
FYI 3405.1.2 "Repair" is likewise worded similar to 3404.1.1 above.
Code references:
