ByInspection
Hello -
We are working with a client who wants to move a canopy structure about 100 yds from its current location. There will be zero changes to the structure and no change in seismic or wind loading conditions (SDC D). There is some discussion right now with the AHJ about evaluating/retrofitting the structure to current standards. We understand that the foundation and anchorage need to be designed to the current code, but this discussion is about the structure itself and whether it needs to be evaluated against the current code.
I've read CEBC 1402.3 & 1402.4 as well as the commentary in IEBC for these sections. We would be taking advantage of the 10% exception rule, "Structural elements whose stress is not increased by more than 10 percent". This language is not clear on whether this 10% is the difference between the old site and new site design parameters, OR if the 10% difference is between as-built design parameters and current design parameters. Based on the language in section 503 of the CEBC, we feel this 10% has to do with any change to the structure that would result in a change in D/C ratio of 10% (like cutting a hole in a shear wall or something).
Lastly, the commentary in the IEBC: "Exception 2 allows additional seismic loads that do not increase stresses in affected structural elements by more than 10 percent. Allowing overstresses of up to 10 percent in existing structural members has been a long-standing rule of thumb used by structural engineers."
What does "additional seismic loads" mean? Additional loads at the new site, or additional loads in the current code (compared with the old code).
Thanks for your help on this!
