MrHaz
We're having some interesting discussions here in the office, and thought you all might like to chime in with your thoughts and opinions.
What is the use group for a Central Utility Plant?
This is located in the boonies of southern MO, and it's a 4k SF building 30'-7" wide. Housekeeping and Storage take up 33.44 ft of the bldg. The next 9 ft is a corridor with 1 hour walls on both sides running front to back (with a set of stair at the back going up to grade). Then next 18' are the Electrical room with the 1 hour fire barrier wall on the West side, and a 3 hour fire barrier wall on the East. The Mechanical room is the next 47 ft. to the East end wall that has double doors that open onto the covered "patio" of sorts that has two (2) Chillers.
We have votes for S-2, F, and U.
Where do you come in, and why? (And the rule for this one is you must back up your reasoning with a reference from 2012 IBC - Thanks)
Haz
Haz
