Codeman2020
For a commercial building with hot water only being used for sinks, can the water heater be set (by the thermostat on the heater) at 140 and only use point-of-use mixing valves at each sink (that lower to the required 110F)? If that is allowed, would that be preferred over a central mixing valve that limits to 110 F since legionella growth in the lines would be a concern? I've seen a central valve used to limit the supply temp to 140 and then point of use valves to lower the sinks to 110, but using both types of valves seems like overkill if there are only public lavatories being supplied.
