Changes in Occupancies
Glennman CBO
Silver Member
We have a building that was approved in the late 40's as a "B" occupancy (Greyhound Bus Station). Over the course of decades and changes in the codes, the modern occupancy would be an "A". Now, an outfit wants to convert it to a business office, which of course would be a "B".
I am only wanting to discuss the changes in occupancies that have taken place over the years with my example. Would you consider it a change of occupancy A to a B, or, since it was considered a B originally, and the new proposed use is a B, then no change of occupancy is taking place?
As an added note, with the size of the building, previous use, etc, I would consider the new use as less hazardous than the previous.
Thanks in advance.
Was the original use documented meaning an actual
[ C. of O. ] as a "B" Occ. Group ?........If so, then
continue using as a "B".......If not documented as a
"B", ...the new "B" Occ. Group [ IMO ] would require
Accessibility [ locally adopted codes ] upgrades
throughout........ADA requirements [ Federal
requirements ] / upgrades will be required regardless.
A B to a B can be a change of occupancy by code definition IEBC CHANGE OF OCCUPANCY. A change in the purpose or level of activity within a building that involves a change in application of the requirements of this code.
IMPO
Permitted as a "B" occupancy, never altered?,still a "B" occupancy.
You will now have a less intense use of the "B" occupancy.
Yes you will need accessible upgrades, ADA, ANSI or Local/state, but you will need accessible upgrades.
Note that not all spaces need to be accessible.......
Yeah, what he said
I have to agree with Mark Handler, although I do appreciate the different views. There is no change in the purpose or level of activities that "involves a change in the application of the requirements of this code". If you isolate the statement "purpose or level of activity" outside of the context, then everything is a change of occupancy. B to a B.
The letter assigned to an occupancy in a particular code edition doesn't matter as much as the definition of the occupancy. This would be a change in occupancy if the original B occupancy didn't include business offices.
On the other hand, if it remained a similar occupancy to a bus station, it would be considered an A-3 now, but this would not be a change in occupancy.
