Conarb said:
104.1 Applications and permits. The building official shall receive applications, review construction documents and issue permits for the erection, and alteration, demolition and moving of buildings and structures, inspect the premises for which such permits have been issued and enforce compliance with the provisions of this code.
Nowhere do I read into your requirement to enforce the code a requirement to tell the permit holder which section he is violating.It is your Item 4 that is adverse to the interpretation presented. Section 104.1 already authorizes and directs the BO to enforce the provisions of this code. It appears that the closing phrase of 104.3 "enforce compliance with the provisions of this code" could be applied to each of the actions required of the BO in this section:
The BO shall:
1. receive applications
and enforce compliance with the provisions of this code (see also 106.1)
2. review construction documents
and enforce compliance with the provisions of this code (see also 106.3)
3. issue permits
and enforce compliance with the provisions of this code (see also 105.1)
4. inspect the premises
and enforce compliance with the provisions of this code (see also 109.3)
If other sections as referenced above already require the BO to do these things, it need not be stated here, unless to clarify that when performing these duties, "enforce compliance with the provisions of this code."
This statement does not read "enforce compliance
in accordance with the provisions of the code." Rather, it mandates that the BO in performing these duties, "enforce compliance
with the provisions of this code," which a strict interpretation could construe to mean that the provisions of the code shall accompany (be with) the enforcement of compliance.
There is no doubt room for other interpretations in its application, as with most sections of the code, but when an earlier poster asked for a reference that could require such a mandate, this one appears to fit the bill.
Even if such a strict interpretation were accepted, it would be challenging to refute any action which referenced 104.1. This would probably not reduce the number of calls requesting clarification of the specific code section referenced, but it is a provision of the code being enforced!
