tbz
Afternoon All,
So, I have a client with a project with the following layout.
Stair minimum stair width confirmed by RFI's with the Architect of Record is 3'-10".
The debate that is being discussed is what area of the mid-landing is the clear width measured to.
I have included a cut view of the mid landing below.
- The handrails are currently full wraps around the outside against the walls.
- From the edge of the nosing to the wall directly a head is 4'-0.25",
- Which leaves 3'-10" from the nosing to the inside face of the landing stringer.
- My position is the landing width is measured the same as the stair width.
- and since this is a continuous landing of the flight exception 3 of 1011.6 applies and Thus, the 4'-0" depth for the mid landing is not required.
- We have a clear width of 3'-10" on the stair flight and 4'-0.25" on the landing to the wall, but 3'-10" to the inside edge of the landing stringers.
- So based on the drawing and a set of stair flights with a clear width of 3'-10" do you find the mid landing clear width compliant with or without the handrail on the mid landing back wall?
