Clear space ADA vs ANSI
Yankee
New England
Am I correct in seeing that ANSI 604.3 requires 60" clear side to side for a WC, and ADA requires only 48" clear side to side for a WC?
If I am correct with that, would it be reasonable to allow the 48" clear in a retrofit that has removed everything in a tenant space except the bathroom wall that holds the plumbing (they do have to change out the toilet for a wall hung unit and slide the lav over, so the wall will need to be disturbed).
If this doesn't fly, I have a follow up question about an electrical room door being accessed thru the ADA bathroom . . .
Thoughts?
Yankee said:
Am I correct in seeing that ANSI 604.3 requires 60" clear side to side for a WC, and ADA requires only 48" clear side to side for a WC?If I am correct with that, would it be reasonable to allow the 48" clear in a retrofit that has removed everything in a tenant space except the bathroom wall that holds the plumbing (they do have to change out the toilet for a wall hung unit and slide the lav over, so the wall will need to be disturbed).
Thoughts?
That 48" dimension is removed in the "new" guidlines, effective in Jan.
