Okay... Section R307 Toilet, Bath, and Shower Spaces. This section specifies that the fixtures shall be in accordance with Figure R307.1 and in accordance with the requirements of Section P2705.1. The figure in R307.1 shows that a clearance space of 21 inches is required in front of toilets.
2009 IRC Section P2705.1 Subsection 5 specifies the same 21 inches of clearance but goes a step farther and specifies... 21-inch (533 mm) clearance in front of the water closet,lavatory or bidet to any wall, fixture or door.
P2705.1 #5 Water closets, lavatories and bidets.A water closet, lavatory or bidet shall not be set closer
than 15 inches (381 mm) from its center to any side wall, partition or vanity or closer than 30 inches
(762 mm) center-to-center between adjacent fixtures. There shall be at least a 21-inch (533 mm) clearance
Now the question. Is the door allowed to swing into that 21-inch clear space?
In my opinion I say yes! What say you others on this forum?
