Definitely not an S-trap, assuming that the pipe above is a dry vent and not carrying drainage from above.Is this an S trap?
Thats what I first thought...If I'm reading Charlotte's catalog correctly, including the hubs the p-trap itself provides 1-1/4" of trap arm length, and the 3x3x2 sanitary tee provides 2-1/8" of trap arm length. So as long as the length of exposed pipe between the two hubs is at least 5/8", then it complies with the crown vent rule.
Boredom or ignorance?Why would you put foam at the dryer box connection?
Why would you not?
That has me wondering about dryer vent being in a wall cavity.Dryer exhaust temp can be as high as 200 degrees when operating normally. The high temperature limiting switch is usually 250 degrees. Spray foam burns at 240 degrees.
New dryers have 2 or 3 temperature limiting devices and are a lot better than older ones. Things do break or fail and I would think foam installed that close to the dryer would be a violation of the Tiger code.
If foam is lower than 451 degrees, then me too...That has me wondering about dryer vent being in a wall cavity.
