Mad Pete Trollo
I just bought a home in a semi-rural area of central Florida. The home is of concrete block construction and was built in the mid-80s. I just have a couple questions about the home's construction; namely, are the blocks used to construct the exterior walls hollow or filled? I've only been in the home for a few days, but I already feel like the air handler isn't running as much as it did when I was in a wood-frame home, so is it reasonable to believe this home might be pretty well insulated??
