Dirtracer85
I am finishing my basement but leaving the utility/laundry room unfinished. Floor joists are perpendicular to the partition wall in question, finished space has drywall ceilings with unfaced fiberglass bat insulation. Even though the utility/laundry room is unfinished Im still rocking the partition wall up to the bottom of the joists because there is kraft faced insulation in between the wall studs. Do I have to do anything in the joist space between the 2 spaces? There is a lot of stuff running between the joist so drywall wouldn't be fun. I have enough mineral wool left over to stuff above the wall between the joists just not sure if that's code. Also are there any additional fire requirements with the drywall on the unfinished side of the partition? Thanks for your help.
