John Gallo
I have a question to add to this. A coworker and I do not see eye to eye on this subject. In a Type 1 & 2 noncombustible, he is saying the Jack stud "can" be of combustible material. Because under exceptions in IBC and IFC, 603.1 exception #14 says "Blocking" such as for handrails, millwork, cabinets and window and "Door frames" does not have to be noncombustible. Now since the door can be of "combustible material" under the IBC and IFC 603.1 Exception #6. He says, The Jack stud is the "Blocking"/Backing for the door so it, in turn, dose not have to be of noncombustible material.
Now i don't see a Jack stud as a Blocking. Blocking Definition says "Uses include filling, spacing, joining, or reinforcing members. Blocking is typically made from short off-cuts or defective, warped pieces of lumber. The term Blocking is also sometimes used by people in construction to refer to discontinuous shims or spacers." I see it as part of the framing/structure as it holds the header and is connected to the king stud that is also made up of noncombustible material. Now he is a seasoned inspector of 40 years. I am only 1 year into being an inspector. So he says, you understand it your way and i understand it my way. I am not trying to ruffle feathers or step on toes, but if i fail someone i want to make sure i can back it up and site the code directly. What is your thoughts on this? "First post by the way"
