Commercial Electrical Inspector Exam
globe trekker
I am getting ready to take the Comm. Electrical Inspector Exam for the 1st time.
Does anyone have any recommendations on the study materials, ...what to bring to the
exam itself, ...what to expect on the exam and anything else that will benefit the exam
takers? What areas are focused on the most, ...are there any/many calculations, etc.?
Thanks! :-)
The only items you will need is the 2008 NEC, a ruler, and a calculator.
Make sure you have tabs for the NEC. The ruler needs to be 7" long. This is the exact width of all the tables in the NEC. USE THE RULER when answering a table question! Make sure the calculator has both solar and battery power, a large clear display, and not too many functions.
Pick out the key word(s) of the question and determine the applicable Chapter, then Article, then Section. For example, if the question is asking about the clearnance of a particular luminaire in a clothes closet, the first thought in you head should be, Chpater 4. Your next thought should be, Article 410. From there, you find Section 410.8. Use this method for each question. Use the Table of Contents and Index to narrow your searches.
There will be calculations, but not an overwhelming number of them, nor are they all that complex. You need to be at least familair with perform each kind. Use ANNEX D for guidance. Time managment is everything, be quick and don't second guess yourself.
I would wish you luck, but I believe proper preparation and dedicated study can out perform any type of luck.
SO GIVE IT YOUR ALL AND DO YOUR BEST !!!
