Commerical bath room ventilation
50/70 cfm per WC, The lower rate is if it doesn't get heavy use, higher if it has periods of heavy use. (2009 IMC)
mj - try this...
403.4 Exhaust ventilation. Exhaust airflow rate shall be provided in accordance with the requirements in Table 403.3. Exhaust makeup air shall be permitted to be any combination of outdoor air, recirculated air and transfer air, except as limited in accordance with Section 403.2.
