sylvan
We are working on a change of use in San Francisco, converting a single story type III private car garage (U) to a three story + roof deck type V single family residence (R3). This project falls under the 2013 California Building Code (uses the IBC model code). The problem we're facing at the moment is the exit travel distance from the roof deck. The building will be fully sprinklered with a type 13-R system, extending our allowable common path travel distance to 125 ft. However, we've got 150 ft from the back corner of the roof deck to the front door. The allowable exit access travel distance is 250 ft, but we're only working with a single exit, so the common path of travel dictates our travel distance.
Here's the question: if we provide two exit access stairs from the roof deck down to the 3rd floor, and then proceed with one exit access stair from 3rd to 2nd and 2nd to ground, does this mean our CPOET limit starts when we reach the 3rd floor? Have we effectively removed the CPOT from the roof deck by providing two exit access stairs down to the 3rd floor?
The definition for CPOET is as follows:
COMMON PATH OF EGRESS TRAVEL. That portion of exit access which the occupants are required to traverse before two separate and distinct paths of egress travel to two exits are available. Paths that merge are common paths of travel. Common paths of egress travel shall be included within the permitted travel distance.
The part about "paths that merge..." is the part that seems to be a "no" answer to my question. The reason I still think this is a valid question is that the path of travel isn't merging on the same floor, it doesn't merge until you reach the top of the stairs on the 3rd floor.
Thanks in advance for your time and help. I look forward to hearing everyone's thoughts.
