Comprehensive Guide to the FEMA Elevation Certificate (Link at bottom of article)
Comprehensive Guide to the FEMA Elevation Certificate: A Pillar of Floodplain Management​
The FEMA Elevation Certificate (FEMA Form FF-206-FY-22-152) is a critical tool under the National Flood Insurance Program (NFIP). Designed to document a building’s compliance with floodplain management ordinances and to support flood insurance premium calculations, it serves as a bridge between property owners, communities, and insurance providers.
Purpose of the Elevation Certificate
The Elevation Certificate is instrumental in:
  1. Floodplain Management Compliance: Ensuring new and substantially improved buildings meet the NFIP and local floodplain ordinances.
  2. Insurance Premium Determination: Accurately assessing flood risks to calculate appropriate flood insurance premiums.
  3. Map Amendment Support: Providing essential data for applications such as Letters of Map Amendment (LOMA), Letters of Map Revision Based on Fill (LOMR-F), and their conditional counterparts.
Important Note: While the certificate is a key document, it does not waive the federal requirement for flood insurance. Only official FEMA map amendments or revisions can remove the flood insurance mandate.
Who Needs an Elevation Certificate?
An Elevation Certificate is necessary for:
  • Post-FIRM Buildings: Structures built after the effective date of the Flood Insurance Rate Map (FIRM).
  • Special Flood Hazard Areas (SFHAs): Properties in zones A, AE, AH, AO, VE, and similar.
  • Substantially Improved Structures: Buildings undergoing renovations or improvements where costs equal or exceed 50% of the pre-improvement market value.
Even pre-FIRM buildings may benefit from obtaining a certificate to evaluate potential savings on flood insurance.
Key Sections of the Elevation Certificate
Section A: Property Information
This section establishes the building's location, use, and ownership. Key components include:
  • Owner’s Name and Address: For correspondence and record-keeping.
  • Building Details: Including lot/block numbers, tax parcel ID, and latitude/longitude coordinates (accurate to at least six decimal places).
  • Photographs: At least two, and preferably four, showing all sides of the building and its foundation. Additional close-up photos of flood openings or vents are required if applicable.
Section B: Flood Insurance Rate Map (FIRM) Information
Details the building's flood zone classification, FIRM panel data, and Base Flood Elevation (BFE). Key elements:
  • Flood Zone(s): Specifies zones such as A, AE, AH, VE, or others.
  • Base Flood Elevation (BFE): Critical for understanding the potential flood depth.
  • FIRM Panel Information: Includes the map number, suffix, and effective/revised dates.
For properties affected by map revisions (e.g., LOMAs), additional documentation is noted in the comments section.
Section C: Building Elevation Information
This section requires elevation data certified by a licensed surveyor, engineer, or architect. Measurements include:
  • Lowest Adjacent Grade (LAG) and Highest Adjacent Grade (HAG).
  • Top of the Bottom Floor (including basement or crawlspace).
  • Lowest Horizontal Structural Member (for V zones).
  • Machinery and Equipment Elevations: Includes HVAC units, water heaters, and other essential systems.
Elevations must align with the vertical datum used for the BFE, typically NGVD 1929 or NAVD 1988. Conversions between datums must be documented.
Section D: Surveyor, Engineer, or Architect Certification
This section validates the data provided in Section C. The certifier must:
  • Include their professional license number.
  • Seal and sign the document.
  • Provide comments on the methodology and any supplementary information (e.g., latitude/longitude sources).
Section E: Building Measurement Information
For buildings in Zone AO, Zone AR/AO, or Zone A (without BFE), Section E can substitute for Section C. Measurements include:
  • Top of the Bottom Floor relative to the natural grade.
  • Platform Height for machinery and equipment servicing the building.
Section F: Property Owner Certification
If applicable, the property owner or their authorized representative certifies Sections A, B, and E for certain zones. This ensures alignment with the building's use and local floodplain management standards.
Section G: Community Information
Community officials document local compliance, including:
  • Permit issuance dates.
  • Certification of as-built elevations for new construction or substantial improvements.
  • Variances granted for floodplain management.
This section emphasizes the role of local authorities in ensuring NFIP standards are upheld.
Section H: Building’s First Floor Height (Insurance Use)
Applicable for all flood zones, Section H helps insurers determine flood risk based on:
  • The height of the building’s first floor above the Lowest Adjacent Grade (LAG).
  • Elevation of essential machinery and equipment.
Photographic Requirements
Photos must:
  • Be recent (taken within 90 days of certification).
  • Include all sides of the building, showing the foundation.
  • Depict flood openings and other relevant structural features.
Digital photos are acceptable and should be clear and labeled (e.g., "Front View," "Rear View").
Using the Elevation Certificate
  1. Flood Insurance Premiums: Accurate elevation data often results in reduced premiums by reflecting lower flood risks.
  2. Floodplain Management Compliance: Helps communities enforce NFIP standards, protecting residents and maintaining eligibility for federal assistance.
  3. Supporting Map Amendments: Provides the technical basis for revising flood zone designations through FEMA’s LOMA or LOMR processes.
Common Errors to Avoid
  • Datum Mismatch: Ensure elevation measurements use the same vertical datum as the FIRM.
  • Incomplete Sections: Every required field must be filled; omissions can delay processing or invalidate the certificate.
  • Inaccurate Photos: Ensure photos align with FEMA requirements and clearly depict the building’s features.
Additional Resources
For detailed instructions and guidance:
  • FEMA Publication 467-1: Floodplain Management Bulletin: Elevation Certificate.
  • NFIP Technical Bulletins: Address specific compliance issues, such as flood openings.
  • FEMA Map Service Center: Access FIRMs and related data at msc.fema.gov.
TBCF Summary​
The FEMA Elevation Certificate is a cornerstone of flood risk management, providing essential data for property owners, insurers, and communities. Its careful preparation and use ensure compliance with NFIP standards, mitigate flood risks, and often lead to financial savings. By understanding its components and adhering to its guidelines, stakeholders can protect properties, lives, and livelihoods from the devastating effects of flooding.
