computer stuff
cda
LIFETIME SAWHORSE
Basement
When I do an "advanced search" this stuff appears at the top. It has happened on two different computers and not related computers
the search feature still works, just wanted to pass it on:::
Warning: Declaration of vBForum_Item_SocialGroupMessage::getLoadQuery() should be compatible with that of vB_Model::getLoadQuery() in ..../packages/vbforum/item/socialgroupmessage.php on line 261
Warning: Declaration of vBForum_Item_SocialGroupDiscussion::getLoadQuery() should be compatible with that of vB_Model::getLoadQuery() in ..../packages/vbforum/item/socialgroupdiscussion.php on line
AND, there is no way to search by date for say 2009 or 2010 items??????
jar546 said:
Thanks for the heads up. I just bumped it to Andrea who handles that stuff that's way over my head.
No big problem everything works
UPDATE:
You should no longer see the error message but the problem is not quite fixed yet and the search function should still work.
What we did was essentially turn off that pesky car overheat light so you don't see it even though the engine is running hot.
Oh no! You've done the unthinkable and suppressed your PHP errors?
...Well maybe I've done that before. Just remember to take the code suppressing errors out if you modify the code to make sure there aren't more errors than you are trying to suppress. Then just pop it right back in and you're good to go.
The forum website has gotten screwy on the computer at work. It balks, freezes and crashes internet explorer. The IT dept. tried a few things and then told me that it will be more trouble than it's worth to fix. This is the only site that is a problem.
And Jeff, I already know that I am more trouble than I'm worth.
I did hear one other site that was having problems can't remember the name of it and since I do not discuss politics and only promote the USA. Off we go!
