What 'proof' is necessary to be able to calculate unconcentrated assembly occupancy at 15sf for tables and chairs vs. concentrated at 7sf? I've heard differing opinions.
on the design side, I always show furniture layouts on my code plans. If the space is filled with tables and chairs on the code plan Bobs your uncle.....
Thank you both, and your answers are what I thought. I only asked because I had one instance where a reviewer said that since the tables and chairs weren't fixed, then I had to use 7sf as if there were no tables and chairs.
I guess it depend on the type of space. For instance I work on a lot of schools and while we typically show a layout of tables and chairs in the cafeterias on our code plans. But we know full well that these spaces will get used for school bake sales and other such events, so we typically go by the worst case and calculate these space at 1 person per 7sf to make sure we have egress capacity for the a realistic worst case scenario.
If its truly a small space its highly unlikely that the furniture will be cleared out and the room used for dense packed seating. I think the BO is just being an ass! Under his logic any conference should be calculated at 1 per 7sf becuase the table and chairs could be cleared out
CDA - how would posting 2 occupant loads work?
Normally see it at like a hotel ballroom or similar setting,
Instead of getting the call all the time, " I have this set up what is the occupant load"
Say do calculation for worst case chair/ table arrangement,,
And
Say do calculation for Building Inspector seminar with just say chairs only
You come up with two different numbers
Post that on the ol sign with say the heading table/ chair and chair only.
So when they call or you get the overcrowding call, just look at the sign, and you do not have to go pull the plans, or measure and calc the room.
Whoa, whoa, whoa.....Maybe it's the FM Tim!.....lol......Going through this right now on a school....FM is calling it 5sf per....
I like to review the exit capacity 1st and if the exit capacity meets or exceeds the requirement for the largest possible occupant load for the occasional event then I am okay with it and will look at the other code requirements (plumbing fixtures & ventilation) based on occupant load for the most common use.Thank you both, and your answers are what I thought. I only asked because I had one instance where a reviewer said that since the tables and chairs weren't fixed, then I had to use 7sf as if there were no tables and chairs.
Regardless of what building regulations say the building owner can deny access to a building inspector. Likely the building inspector will be able to obtain an administrative warrant compelling the owner to allow access but we must still respect the legal rights of the building owner.
This posting also raises questions regarding the limits of the discretion of the building official or FM.
