Concrete Wall reinforcement
KZQuixote
Sawhorse
Bend, Oregon
Hi Folks,
Based on the 2006 IRC. A couple of scenarios:
First:
12" concrete foundation wall
8' tall
7' unbalanced backfill
Type SC soil
Second:
10" concrete foundation wall
7' tall
Type GW soil
Question What size vertical reinforcement on what centers for each case and where did you find the requirements?
Thanks in Advance
Bill
Thanks Daywalker,
That's where I was looking. Table R404.1.1(5) says PC for each configuration. Unfortunately that's not the answer that I was being asked to retrieve.
Thank You
Bill
Structural plain concrete has no reinforcement or with less reinforcement than the minimum amount specified for reinforced concrete. In other words, plain concrete does not require reinforcement.
Ok, It happened again! I was asked to return the size and spacing of the vertical reinforcement for an 8" concrete foundation wall 9' tall with 7' of unbalanced backfill. With type SC soil. Table R404.1.1(5) returns #6 @ 38". Unfortunately this choice was not was not available.
2006 IRC
Am I missing something?
TIA
Bill
you also need to know the lateral soil load, but the table footnotes allow you to figure the equivalent amount of steel using smaller bars spaced closer.. it's a pain in the neck to do.. finding #6 on the concrete guys truck is pretty rare. And you can interpolate the table; however when the next step up allows plain concrete that's hard to do.. engineered design is the only other option.
