north star,
I apologize for not referencing the IPC:
802.3 Waste receptors. Waste receptors shall be of an approved type. A removable strainer or basket shall cover the waste outlet of waste receptors. Waste receptors shall be installed in ventilated spaces. Waste receptors shall not be installed in bathrooms, toilet rooms, plenums, crawl spaces, attics, interstitial spaces above ceilings and below floors or in any inaccessible or unventilated space such as a closet or storeroom. Ready access shall be provided to waste receptors.
If it helps with the disposal location the following excerpt from the 2015 commentary is self-explanatory for deleted locations; “the prohibition of not locating waste receptors in bathrooms, toilet rooms, closets or storerooms has been deleted. The prohibition for locating waste receptors in these areas was based on the belief that these receptors would be used for urination. The fact is, any inappropriate location could be used for urination, so the presence of waste receptors does not invite inappropriate behavior any more than a lavatory or a mop sink would. Removal of these prohibitions allows for common installations of clothes washers in a dwelling unit’s bath or toilet room; floor sinks or hub drains for T&P discharge; pan drains in toilet rooms, storerooms and closets where water heaters are installed; and floor drains in storerooms and closets for capturing condensate from air conditioning units.”
In reference to the definition of "Approved" the following explanation from the IBC Handbook:
APPROVED. Throughout the code, the term approved is used to describe a specific material or type of construction, such as approved automatic flush bolts mentioned in Section 1010.1.9.3, Item 3, or an approved barrier in interior exit stairways addressed in Section 1023.8. Where approved is used, it merely means that such design, material, or method of construction is acceptable to the building official (or other authority having jurisdiction), based on the intent of the code. It would seem appropriate that the building official base his or her decision of approval on the result of investigations or tests, if applicable, or by reason of accepted principles.
