Karencita42
Hello all,
Hope all are well.
I have a condo that I rent out and I want to replace the tile with newer more modern style. The condo association said I just need to ensure that the tile is installed in accordance with sound proofing etc... see below.
Condo response: "You have to be extra careful in case of new flooring. The rules specifically talk about the sound proof insulation required in the building."
I did a lot of online research and can't find anything on sound proofing a concrete slab floor with tile. I did however find videos on other materials to prevent from cracking, which I will defenitely use. I am just a bit confused.
Any info is appreciated.
Hope all are well.
