Conference room occupancy
Robert
Pinole, CA
Hello. I am working on a TI and using the CBC. I believe the IBC allows an Assembly occupancy load rating to be considered B if less than 50 occupants or 750 sq. ft. (non-fixed seating...basically a conference room). Is this called out somewhere in the CBC? If not, can I use it from the IBC and which section is it? Thank you.
Hello. I am working on a TI and using the CBC. I believe the IBC allows an Assembly occupancy load rating to be considered B if less than 50 occupants or 750 sq. ft. (non-fixed seating...basically a conference room). Is this called out somewhere in the CBC? If not' date=' can I use it from the IBC and which section is it? Thank you.[/quote']Look in the definition chapter 3 for assembly
Maybe 393.1 ex 1,2,3
Maybe 303.1 ex 1,2,3
