At the footing inspection, I noticed that there were two SSTB at this corner. The plan showed both HDs and different sizes. I explained that only the 8A made sense and they should call the engineer and ask her if she really meant for there to be two on the same post. Upon re-inspection for corrections, they were still there and they said that the engineer was adamant that there be two. I said OK but you cant put them both at the bottom and explained the use of a coupler nut and all-thread. They went back to the engineer and she took it a step further by adding the 4x.
