Yikes
Client owns 2 adjacent lots, each with a separate building with zero setback on the shared property line.
Sometime in the 1980s or earlier a 3' wide door opening was created between them at the 2nd floor level, for convenience.
The door is fire rated 120 minutes, just like the wall rating on the building.
Buildings are too big to collectively be calculated as a single structure.
I have no records of a building permit, but this client is the type that does not bootleg things.
Was there some code back then that allowed openings on a property line wall?
