I am working on renovating a convent.
The occupancy is R-2 as per code.
Its a three story total including the basement. The basement will be a utility and storage for the units. Will this change the occupancy to mixed use cause we are adding storage (S)?
Occupant load calculation is 200sf gross for all areas? or should i take the storage and have it at 500SF Gross?
As for accessiblity, the building is existing and not elevator serviced, it has a total of 5 sleeping units all on the 2nd floor (not elevator accessible). Would any of the units need to be type A or B or none?
Its an all male 5 sleeping unit facility. should i split the occupancy to male and female?
Thank you!
Thank you!
