Mech
2009 IPC
F-1 Bakery use (they mix seasonings together and try their new recipes / concoctions) with a dishwasher, three bowl sink, two bowl sink, and two hand sinks. They have a range and a deep fryer to create grease.
The two bowl sink discharges into a floor sink with a loading of 2 dfu. The three bowl sink discharges into another floor sink with a loading of 2 dfu. The dishwasher uses 5.4 gal per cycle, so I am saying that is 5.4 gpm which is equivalent to 10.8 dfu. IPC 709.3 Values for continuous and semi-continuous flow, listed below, says 1 gpm = 2 dfu.
The flow used to size the grease traps for the two bowl sink, the three bowl sink, and the dishwasher is 61 gpm (using PDI G101.) When the water leaves the grease traps and enters the building sewer, what dfu load do I use? Do I use 14.8 dfu (the loading going into grease traps) or is it 122 dfu (61 gpm * 1 gpm @ 2 dfu)?
Thanks is advance.
709.3 Values for continuous and semicontinuous flow. Drainage fixture unit values for continuous and semicontinuous flow into a drainage system shall be computed on the basis that 1 gpm (0.06 L/s) of flow is equivalent to two fixture units.
Thanks is advance.
