Copper Clad Aluminum Is Back in a Big Way
In recent years, the construction and electrical industries have witnessed a resurgence in the use of copper-clad aluminum (CCA) wiring, a composite conductor that combines an aluminum core with a copper exterior. This renewed interest stems from advancements in manufacturing that have significantly improved the quality and performance of CCA wires, making them a more viable alternative to traditional solid copper wires.
Historically, copper-clad aluminum wires faced criticism due to concerns about their durability and conductivity. However, modern production techniques have addressed many of these issues, resulting in a product that boasts improved mechanical strength, flexibility, and corrosion resistance. These enhancements have helped CCA wires overcome the stigma associated with earlier versions and have paved the way for their broader acceptance in the industry.
The National Electrical Code (NEC) has responded to these improvements by updating its guidelines to incorporate the use of CCA wiring in certain applications. This endorsement reflects a growing confidence in the reliability and safety of CCA wires when installed and maintained according to NEC standards.
One of the primary benefits of CCA wiring is its cost-effectiveness. Aluminum is significantly cheaper than copper, and the combination of an aluminum core with copper cladding reduces material costs while maintaining adequate conductivity for many applications. Additionally, CCA wires are lighter than their pure copper counterparts, simplifying handling and installation and potentially reducing labor costs.
Another important consideration is the impact of CCA wiring on copper wire theft, a persistent issue on construction sites and in other settings. Copper's high scrap value has made it a target for thieves, who often burn off insulation to retrieve the metal. However, the lower melting point of aluminum can cause the core of CCA wires to melt during this process, rendering the wire useless and decreasing its resale value. This risk, combined with the overall lower scrap value of CCA wires compared to pure copper, may deter theft and reduce losses from stolen materials.
While the resurgence of copper-clad aluminum wiring presents clear advantages in terms of cost and theft prevention, it also requires careful consideration during installation. Proper connection methods and the use of listed connectors are essential to prevent issues such as galvanic corrosion and ensure safe, reliable performance.
The copper cladding solves one of the problems with aluminum wiring which was that an insulating oxide would form on the aluminum, but there were other problems.
One of the BIG problems with aluminum wiring in the 1970s was that it would the heat from running current through it would cause the aluminum to expand. The screws would prevent expansion so the circular shape became an oval which would pull away from the screw as it cooled down. Eventually there would be sparks at the gap. Bellville washers and conductive paste were used with larger conductors to overcome this problem, but wiring devices used with smaller branch circuit conductors didn't have them.
I would be very nervous about specifying or substituting CCA wiring until it has a good history for a decade or more.
