Correct way to build an insulated and unventilated rafter space in a cold climate
retire09
Silver Member
Alaska
If you have a rafter with the ceiling on the bottom and roof deck on top fully insulated with no ventilation in a very cold climate; should you have a vapor barrier on the bottom?
If you do have a vapor barrier on the bottom, can you also have foam insulation on the deck under the roof covering?
How do you build a "Hot" roof in a cold climate without creating a moisture problem?
No interior vapor retarders are installed, the required minimum thickness of impermeable insulation against the roof deck acts as the vapor barrier; see 2009 IRC section R806.4
Depends on the product though, they can have a variety of impermeability.
