708.4 Continuity. Fire partitions shall extend from the top of
the foundation or floor/ceiling assembly below and be securely
attached to one of the following:
1. The underside of the floor or roof sheathing, deck or
slab above.
2. The underside of a floor/ceiling or roof/ceiling assembly
having a fire-resistance rating that is not less than
the fire-resistance rating of the fire partition.
1. Fire partitions shall not be required to extend into a
crawl space below where the floor above the crawl
space has a minimum 1-hour fire-resistance rating.
2. Fire partitions serving as a corridor wall shall not
be required to extend above the lower membrane of
a corridor ceiling provided that the corridor ceiling
membrane is equivalent to corridor wall membrane,
and either of the following conditions is met:
2.1. The room-side membrane of the corridor
wall extends to the underside of the floor
or roof sheathing, deck or slab of a fireresistance-
rated floor or roof above.
2.2. The building is equipped with an automatic
sprinkler system installed
throughout in accordance with Section
903.3.1.1 or 903.3.1.2, including automatic
sprinklers installed in the space
between the top of the fire partition and
deck or slab above.
3. Fire partitions serving as a corridor wall shall be
permitted to terminate at the upper membrane of the
corridor ceiling assembly where the corridor ceiling
is constructed as required for the corridor wall.
4. Fire partitions separating tenant spaces in a covered
or open mall building complying with Section
402.4.2.1 shall not be required to extend above the
underside of a ceiling. Such ceiling shall not be
required to be part of a fire-resistance-rated assembly,
and the attic or space above the ceiling at
tenant separation walls shall not be required to be
subdivided by fire partitions.
